DCM Reset
DCM reset circuit design on virtex5:
How many cycles (How long) should we wait once a reset of 3 cycles long is assserted after an unlock has been detected to check whether the DCM is locked or not?
Best regards
iozcelik
Teacher rcingham
Re: DCM Reset
Keep checking until it reported as locked... Simulate it!
Or you could use a PLL, which deasserts its 'locked' output in a more useful manner.
"If it don't work in simulation, it won't work on the board."
Re: DCM Reset
the question is: After a reset, how long does it take for a DCM to get locked under normal conditions.
giving another reset too soon will prevent DCM from getting locked. settling time for a DCM is what I wonder.
Instructor
Instructor
Re: DCM Reset
Lock time is specified in the Virtex 5 data sheet (ds202) under the very enlightening title of
"Miscellaneous Timing Parameters."  The maximum lock time depends on the frequency
of the input clock, and also whether you're using the FX outputs or the DLL outputs.  In no
case is it more than 5 ms for DLL or 10 ms for FX outputs.
Then to throw a monkey-wrench into the works, they add:
Multiplier factor for DLL Lock time with Fine Shift:  2.0
So if you use the "fine" shift feature of the DLL you could double the lock time.
It is reasonable to assume that these lock times are dependent on the input clock being
stable during the entire locking period.
Another word of caution on DCM's:
DCM outputs DO NOT TOGGLE while you assert reset!  DON'T USE THE DCM'S OUTPUTS
TO CLOCK THE RESET LOGIC!
-- Gabor
-- Gabor
Re: DCM Reset
Teacher eteam00
start a new thread!
qd0090,
You are new here.  Our hosts have established a set of rules for these forums, you can read them here.
First:  Please do not post a unrelated topic or question to an existing thread.   Start a new thread, so the two conversations can remain distinct and concise.
Second:  Please do not post the same topic or question in multiple threads.  This is called cross-posting.  Keep the discussion in one thread, which makes it easier to follow the discussion and makes it easier to participate in the discussion.
If you are using a Virtex family part, please re-post in a new thread in the Virtex forum.
If you are using a Spartan family part, please re-post in a new thread in the Spartan forum.
Thank you for respecting the rules.  I have placed the same response in your cross-posted entry.
-- Bob Elkind
SIGNATURE:
Summary:
