Participant kbj1213
Help : Virtex 5 DDR ll SDRAM Use
I'm beginer of FPGA control by verilog.
I have shed light on led of FPGA by verilog.
Now, I'd like to do it using Memory of FPGA.
I checked my Virtex 5 XUPV5-LX110T has DDR ll SDRAM.
I followed MIG guide file(ug086) and made mig module.
But at page 69 of "ug086" file, guide explains how to create design for Xilinx Reference Boards.
I don't know anything about what it means. And I tried to do it by choosing Xilinx Reference Boards in MIG Output Options. But there was only one sentence,  "The ML561 has a MIG reference design available. Please refer to the following link for the MIG reference design board files.".
I don't know anything what should I do after making mig module.
Could you explain how I could turn on led by Memory in detail?
Re: Help : Virtex 5 DDR ll SDRAM Use
you can check this guide
http://www.xilinx.com/products/boards/ml505/ml505_12.1/docs/ml505_mig_design_creation.pdf
Thanks and Regards
Balkrishan
UG199 -  Virtex-5 FPGA ML561 Memory Interfaces Development Board User Guide ( ver1.2.1, 9841 KB ) [PDF]
This user guide describes the Virtex®-5 FPGA ML561 Memory Interfaces Development Board, which is the heart of the Virtex-5 FPGA ML561 Memory Interfaces Tool Kit. The tool kit provides a complete development platform to interface with external memory devices for designing and verifying applications ...
Thanks and Regards
Balkrishan
Participant kbj1213
Thank you very much.
I have seen this data file.
But I didn't know what Chipscope does.
Could I hear what Chipscope does?
And How could I download the program?
Check ug750
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug750.pdf
