How to export the directed routing constraints to the UCF file?
I am working with ISE 14.7 targeting a Virtex-5 FPGA. I manually placed and routed some components of my design. I know that those new constraints (PLACE&ROUTE) are written automatically in PCF file. But I am wondering to know how can I export the manual routing and placement constraints from FPGA Editor to the main UCF of my design??
In the following link it was written : " If you want to maintain both routing and placement, export the directed routing constraints to the UCF file" .... but how to do it??
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_imp_strategies_using_fpga_editor.htm
Kind replies are in advance appreciated.
Thanks and Regards,
Instructor
Instructor
Re: How to export the directed routing constraints to the UCF file?
Open the routed design in FPGA editor.
Select the net(s) you want to constrain.
Go to Tools --> Directed Routing Constraints...
A window will pop up as below.  Default is to append constraints to the end of your project UCF file.
You can also select nets within that pop-up window.
-- Gabor
Instructor
Instructor
-- Gabor
SOLVED....!
Thank you so much @gszakacs (Gabor) for your guide. The problem got solved !
