UG222 readme.txt - Where is this file? It is only mentioned once.
On page 20, section 16, RESET Switch (Active-Low), it says "Refer to the readme.txt file for implementation of this user pin"
I can't find readme.txt anywhere?
I have an AFX-FF1760-500 proto board.
Thanks for any help!
The readme.txt file would have been on the CD that was shipped with the board.  Although, I don't know why the footnote makes a reference to this file as it seems uneccessary as the description in UG222 provides all of the information that you would need.
