Virtex 4 FPGA GPIO I/O Issue (No Output)
i have designed a board using VIRTEX4 (XC4VSX35-11FF668). Impact detects FPGA & PROM, i can program my FPGA.
Using Chipscope pro i can see the toggelled output signal.
Problem is regarding the GPIO output, i can't see any output of the signals at GPIO's. i m using pin A23,B23,A24, B24.
but no output at the GPIO.
Plz provide some help.
THANKS
What does your deisgn do ?
Outputs on GPIO depends on any inputs or you have driven them with constant pulses/logic?
Historian
Historian
@rehanbunny wrote:
What's a GPIO?
Constantly driven, i mean
IO1 = 1'b0;
IO2 = 1'b1;
IO3 = ~ IO3;
You're going to have to be a lot more informative than that if you want to get some useful help.
You state that you have designed a board (really? The whole board?) so it's a given that nobody here has any knowledge of it and its functions.
What is your FPGA design supposed to do? Can you post some code related to the failing part of the design?
Have you simulated your design?
"That which we must learn to do, we learn by doing." - Aristotle
