Virtex 6 - "CLKFBOUT_MULT_F set to a value that is outside the valid range"
I am attempting to generate a bit file for the ML605 board using XPS 11.5. When I add the DDR3 controller, I get this error:
"MMCM_ADV symbol
"physical_group_DDR3_SDRAM/DDR3_SDRAM/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if
_0/u_phy_read/u_phy_rdclk_gen/base_perf/DDR3_SDRAM/DDR3_SDRAM/mpmc_core_0/gen
_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rdclk_gen/u_mmcm_clk_base" has
attribute CLKFBOUT_MULT_F set to a value that is outside the valid range of 5
to 64."
According to "http://www.xilinx.com/support/answers/34564.htm, I should be able to fix this using a manual edit of the 'system.mhs' file. However, in this file, the CLKFBOUT_MULT_F value of the only clock generator in the design begins at 6 and by some tweaking I have increased it to 24 but I still get the error.
What am I doing wrong?
Re: Virtex 6 - "CLKFBOUT_MULT_F set to a value that is outside the valid range"
The workaround I mentioned should be placed in system.mhs according to the answer I linked. But the only CLKFBOUT_MULT_F in there is 6.0, so that was the point where the 'solution' did not work for me.
I added the line to my 'data/system.ucf' file and it ends up with an error that the constraint can not be found. I found a line in 'synthesis/ddr3_sdram_wrapper_xst.srp' specifying that the multiplier is 2:
Elaborating module <MMCM_ADV(BANDWIDTH="OPTIMIZED",CLKIN1_PERIOD=2.5,CLKIN2_PERIOD=10.0,CLKOUT0_DIVIDE_F=2,CLKOUT1_DIVIDE=10,
CLKOUT2_DIVIDE=10,CLKOUT3_DIVIDE=10,CLKOUT4_DIVIDE=10,CLKOUT5_DIVIDE=10,CLKOUT6_DIVIDE=10,CLKOUT0_PHASE=0.0,CLKOUT1_PHASE=0.0,
CLKOUT2_PHASE=0.0,CLKOUT3_PHASE=0.0,CLKOUT4_PHASE=0.0,CLKOUT5_PHASE=0.0,CLKOUT6_PHASE=0.0,CLKOUT0_DUTY_CYCLE=0.5,
CLKOUT1_DUTY_CYCLE=0.5,CLKOUT2_DUTY_CYCLE=0.5,CLKOUT3_DUTY_CYCLE=0.5,CLKOUT4_DUTY_CYCLE=0.5,CLKOUT5_DUTY_CYCLE=0.5,
CLKOUT6_DUTY_CYCLE=0.5,CLKOUT0_USE_FINE_PS="TRUE",COMPENSATION="INTERNAL",DIVCLK_DIVIDE=1,CLKFBOUT_MULT_F=2,
CLKFBOUT_PHASE=0.0,REF_JITTER1=0.005,REF_JITTER2=0.005)>.
 If that is indeed thecore of the problem, did your UCF workaround meant to be changing that value?
 Edit:
I've added the following to the 'data/system.ucf' file (also to maintain the 2/1 ratio between multiplier and divider since my first attempt shifted the clock for the DDR3 to 2GHz):
INST "*/u_mmcm_clk_base" CLKFBOUT_MULT_F = 6;
INST "*/u_mmcm_clk_base" DIVCLK_DIVIDE = 3;
The bitstream is now proceeding without errors (it seems) so this might have solved the problem for me.
Does this mean the DDR3 controller from XPS 11.5 has a bug?
Edit: it seems the MMCM itself has the problem and will be fixed in XPS 12.1: http://www.zylinks.com/support/answers/34099.htm
Message Edited by cyberwizzard on 03-20-2010 07:41 AM
Message Edited by cyberwizzard on 03-20-2010 04:27 PM
It isn't clear where you in the design flow you tried to implement the work around.  Try adding the following to your top level UCF file.
INST "physical_group_DDR3_SDRAM/DDR3_SDRAM/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if
_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rdclk_gen/u_mmcm_clk_base"  CLKFBOUT_MULT_F = 5;
 Edit:
