ho w to use bram of virtex 5
i want to store the data in bram and aafter some operation i want the data back how can i do this.
i had made a module of ram but in that when i call  ram module and write something it store the values but when i call ram in other module and try to read the data, i m not getting the data( it take as other module). thats y i want to know how i can use the internal bram of virtex 5
thanking you
Re: ho w to use bram of virtex 5
Can you read the data from BRAM during simulation?
Instructor
Instructor
Post your code so we can take a look at it.
Did you use the Block Memory Generator wizard in ISE?
Chapter 4 of the Virtex 5 User Guide is dedicated to Block RAM.
- Bob Elkind
SIGNATURE:
Summary:
i wrote a program of bram it can write and read  the data.
but in same module. if i instantiate the bram for write in one module i am not able to read the data of ram in other module.
here the problem occurs.
module bram (clk, add, data, rd, wr, cs,dataout);
input clk;
input rd;
input wr,cs;
input [9:0] add;
input [7:0] data;
output[7:0] dataout;
reg [7:0] mem [1023:0];
reg [7:0] read_a;
integer i=0;
integer j=0;
always @(posedge clk)
begin
if(cs&&wr&&!rd)
begin
i<=i+1;
mem[add+i]<=data;
end
else
if(cs&&!wr&&rd)
begin
j<=j+1;
read_a<=mem[add-j];
end
end
assign dataout=read_a;
endmodule
i  am trying with this code to write data in one module and read in other  module. but its not happening. pls suggest some other method
