problem in code vhdl when use virtex 5 ml506
i have to interface with ac97 codec by vhdl from i found on this forum, everything was fine i can hear audio signal i want, bit when i want to process this audio signal i meet a problem for example when i want to store signal in left and right channel of input ac97 codec, so i use a module  like this
process(clk)                              -- clk for flipflop is clk for ac97 codec
begin
 if clk='1' and clk'event then
  if ac97_ready='1' then             -- ac97_ready will set '1' each 48Khz has a new samples from thi input
x<=data_in (31 downto 16);    -- data in of left channel of ac97 codec
y<=data_in(15 downto 0);       --  data in of right channel of ac97 codec
end if;
end if;
end process;
Sdata_out<=x&y;                     -- output of ac97 codec
but when i download bit file into the board event when i dont connect input of the codec with my laptop, my earphone still hear some things, some things have sound like "boil water"-noise so i dont understand why it happen ???, i try to fix this but doesnt work
PS: if i just use command x<=data_in(31 downto 16) and remove y<=data_in(15 downto 0) in process then the output i can hear audio signal from left channel ( of couse cant hear about right channel
Re: problem in code vhdl when use virtex 5 ml506
What is the frequency of  clk in your process, is this the same extarnal clock that you provide to  AC97?
Can you increase it and check?
I think one/more of the lower bits might be inducing noise you may find it by removing one bit at a time  and check if the bit is somehow effected on your board.
Ex:-
y<=data_in(15 downto 1) & '0';
y<=data_in(15 downto 2) & '0'  & data_in(0);
Historian
Historian
begin
end if;
end if;
end process;
Did you simulate your design?
