Visitor bilbaena
Creating a project for XC4VSX25, but using the 35
Theoretical question:
Say I didn't want to upgrade to the Logic Edition and just wanted to use the WebPACK.
If I have created a project in the Xilinx ISE that has the XC4VSX25 selected, but have a 35...
Would I be able to pull this off? (provided that my code does not excede the specs of a 25)
Is the XC4VSX35 strictly not supported by the WebPACK edition because the ISE doesn't know how to configure it?
Or could the ISE try to configure a 35 thinking it was a 25?
Edit ----- Not trying to cheat the system here. We will be upgrading if necessary.
Thanks for your time,
Anton
Advisor eilert
Advisor
Re: Creating a project for XC4VSX25, but using the 35
Hi Anton,
simply no.
The resulting bitfile will not be accepted by a different device.
Apart from device identifiers, the contents just won't match the different structure.
Have a nice synthesis
  Eilert
Advisor eilert
Advisor
Hi Anton,
simply no.
  Eilert
Visitor bilbaena
Eilert,
Thanks for the quick reply.
I assumed there was no way... the different FPGAs must have different architectures, different pin locations etc.
Thanks again,
Anton
