Problem importing ReedMullerBasis_LUT_sp_r11_d32 from ISE to Vivado
We are porting a project from ISE to Vivado.
The project uses LogicCore IP - ReedMullerBasis_LUT_sp_r11_d32
When I try to import it into Vivado, I get an error-
[Project 1-160] Problems encountered while importing IP 'blk_mem_gen_v7_3'. Fail reasons:-
Failed to import IP '/home/saiuser/Documents/BhawandeepSIngh/XilinxISE/Projects/pusch_original/Source/virtex6_lib/ReedMullerBasis_LUT_sp_r11_d32/blk_mem_gen_v7_3.xco'. Import is not supported for this IP.
What am I doing wrong here ?
Thanks and sincerely
Bhawandeep Singh
Re: Problem importing ReedMullerBasis_LUT_sp_r11_d32 from ISE to Vivado
Hello Bhawandeep,
When importing from ISE to Vivado the definitions don't get transferred. You will have to do the following steps on Vivado.
1 Go to Project Settings.
2. The General Setting Window will have a section for Language Options.
3. Click on "..." of the Verilog Options.
4. A new window will pop up.
5. Under Defines click the + button and add FPGA in the Name tab.
6. Apply the new settings and synthesis the project.
The errors will be solved using the steps above.
Hope this helps.
-Vanshika
Hello Bhawandeep,
Hope this helps.
-Vanshika
Visitor shanep1
Thanks for the help everyone, i was following this thread as i too had similar issues and needed a solution and now i have one thanks to you guys.
Shane.
