Virtex-6 Translate error
  I have generated a fir filter through System Generator,and import ngc into my ISE project. it has wrong:
ERROR:NgdBuild:604 - logical block
'user_define_module_top_inst/udm_lreg_core_inst/correlator_ctrl_i/nco_acc_cw_
i/ddc_cor_x0/pfir_631d5b704c/fir_compiler_5_0_4/fr_cmplr_v5_0_f9207259caf9fa5
2_instance' with type 'fr_cmplr_v5_0_f9207259caf9fa52' could not be resolved.
A pin name misspelling can cause this, a missing edif or ngc file, case
mismatch between the block name and the edif or ngc file name, or the
misspelling of a type name. Symbol 'fr_cmplr_v5_0_f9207259caf9fa52' is not
supported in target 'virtex6'.
i do not know  where is wrong,Can you help me?
thank you !
Re: Virtex-6 Translate error
Hi @fanwei
Can you check if the target device is same for the FIR filter and the ISE project?
Looks likes the system generator target part is set to Virtex-5 and the ISE project is set to Virtex-6
Thanks,Vijay
Hi, the target device in System Generator and ISE Project are  Virtex-6.
I have change the generate language Verilog to VHDL, but it is has more error.
