xil_tour
2018.2 to 2018.2.xdf migration, xclbin not available please build
I've changed my IDE from SDx 2018.2 to 2018.2.xdf so I'm in the process of migrating my codes.
They were working, but now under XDF, I got this error in SW and HW emu:
XILINX_OPENCL="/home/me/Xilinx/SDx/2018.2.xdf/"
LD_LIBRARY_PATH="/home/me/Xilinx/SDx/2018.2.xdf/platforms/xilinx_u200_xdma_201820_1/sw/lib/x86_64:/opt/xilinx/xrt/lib/:/home/me/Xilinx/SDx/2018.2.xdf/lib/lnx64.o:/home/me/Xilinx/SDx/2018.2.xdf/lib/lnx64.o/Default:/home/me/Xilinx/SDx/2018.2.xdf/lnx64/tools/gcc/lib64"
Found Platform
Platform Name: Xilinx
XCLBIN File Name: sobel
INFO: Importing xclbin/sobel.hw_emu.xilinx_u200_xdma_201820_1.xclbin
ERROR: xclbin/sobel.hw_emu.xilinx_u200_xdma_201820_1.xclbin xclbin not available please build
Any help is welcome.
rsarkari
Hi @xil_tour ,
On the left side, in the project explorer, you will have Emulation-SW tab. Under this, you will have one <some name>.xclbin file. Take this name and put it in the Run->Run Configurations->Arguments tab or tick mark the "Automatically add binary containers".
Tell me if you face any issues.
Rajat
Kindly note- Please mark the Answer as "Accept as solution" if the information provided is helpful.
rsarkari
Hi @xil_tour ,
Could you please tell me where is your xclbin located and what are the command line arguments you are giving while executing the application?
Rajat
xil_tour
I don't know what/where is xclbin. Where is it supposed to be ?
According a search into my filesystem, I have a few ones here and there, but not related to my new environment.
I compile through the IDE, the compilation line is quickly replaced in the console, I barely can see it, can you tell me where I can get back access to it please ?
rsarkari
Hi @xil_tour ,
Rajat
xil_tour
Mmm I don't have this file, I guess the compilation went wrong.
Where can I see the build log please ?
The launch resets the console, I can't see that.
xil_tour
Oh silly me, I forgot to add the binary container in the Application Project Setting window...
Thanks for your help.
