Error while launching program - Standalone Debugger
I've tried to build a standalone application on SDSoC (lab 6 in the tutorial source: https://github.com/Xilinx/SDSoC-Tutorials/blob/master/getting-started-tutorial/lab-6-debug.md)
However, when I load the debugger ((Debug As > Launch on Hardware), I faced with an error (as the attached image).
Is there any idea for this, please share me?
My env: Ubuntu 16.04, SDx 2018.2, ZC706 board with full connection
Thank you,
TuanH
I solved this follow this topic: https://forums.xilinx.com/t5/Embedded-Development-Tools/Vivado-2016-1-SDK-launch-problem/td-p/69361
Actually, the SDSoC environment also base on Eclipse, that why the bug happens on Ubuntu 16.4
Best Regards,
Tuan
Hi @tuanho27
Kindly share SDx log.
Best Regards,
Nutan
Best Regards,
Nutan
Hi @nutang,
Thanks for replying.
I attached the log report
Best Regards,
Tuan
