pmpakos
Event tracing from command line in SDSoC 2018.1
Someone has posted this for SDSoC 2019.1 ( https://forums.xilinx.com/t5/Vitis-Acceleration-SDAccel-SDSoC/Event-tracing-from-command-line-in-SDSoC-2019-1/m-p/1077308#M4965 ) however noone answered.
Is there any way to import sds_trace_data.dat to trace the application, after it is executed? I do not use SDx GUI, I do everything through command line, so I would like to ask if I would be able to import this .dat file in SDx after the execution on my MPSoC (ZCU102)
