ljgibbs
Fail generate bsp in vitis19.2 with lwip
hi all
when I add lwip to my bsp and generate it,it fail and get error msg:
Error:Hw specification provided does not have the HwDb.Plz check you .xsa
I'm new to Vitis,I'm confused with this situation.
THX
nutang
Hi @ljgibbs
Glad to hear that the issue is resolved.
Platform build/Generation is documented below.
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk420476775.html#fcr1566226841785
Best Regards,
Nutan
rajut
Can you please share the exact steps  and also attach the xsa to this post if possible?
Raju
ljgibbs
Hi rajut
I export .xsa again as a new platform and try generate bsp again.It's Ok this time. So wired...
Maybe I generate bsp before build platform cause this error,I'm not sure.
by the way,the platform have to be 'built' and get rid of tag 'out of date'?  I'm confused because there is no step to build hw_platform in SDK.
THX
nutang
Hi @ljgibbs
Best Regards,
Nutan
ljgibbs
Hi nutang
Thank for your help.Could you help me with another issue on SDK?
https://forums.xilinx.com/t5/Ethernet/Can-t-generate-a-bsp-with-a-axiethernet-IP-SDK18-3/m-p/1063513#M17790
olupj
@nutang
This worked for me as well but how is it different than doing a "Clean Project" / "Build Project" cycle (which failed on an XSA with the same error after generating several)?
Jerry
