afusco
Get program stdout from remote hardware
Before I can start a project, I want to run a successful hello world program on a Zedboard.
The zedboard is connected to a remote computer through a usb cable (connected to the jtag port). This computer runs  hw_server (2019.2) on ubuntu 18.04.
I'm running Vitis/Vivado 2019.2 as well on my machine (windows 10).
Please help me to get the hello world output on my screen.
The thing is that I get no error and I'm not sure where to look for my program's output in Vitis.
I'll write everything I've done step by step.
1- create a new vivado project.
1a- Create block design -> Add Zynq -> Run block automations-> connect clocks
1b- Create hdl wrapper in sources
1c- Generate bitstream
1d- export hardware including bitstreams, generates an xsa file.
2- In vitis, Create new application project and create its platform from the exported XSA. I select C, standalone OS, hello world project.
First question: do I need to select the "generate boot components"?
Now the hard part.
Second question: In the BSP settings i can choose stdin and stdout either as "ps7_uart_1" or "ps7_coresight_comp_0" ?
(actually i tried both and neither worked)
3- build project, this builds the elf file.
4- I create a "Single application debug" configuration. I set the correct connection (not local but to the server).
In the "common" tab, I'm not sure if I should select allocate console or not.
5- Click Run...
The FPGA is programmed.
The elf file is downloaded to the board. Arm processors  running.
No "hello world" output is seen.
I tried to run this step manually from the xsct console, I run "jtagterminal -start", then "con"... same thing, no error, no output.
I believe there's one little step that I'm missing and it's running me crazy as I basically lost a day trying to run an hello world.
Thank you very much for your help
