ananya.muddu
How to collect hardware/software traces from command-line?
Chapter 9 in UG 1027 describes how to collect hardware/software traces from the SDSoC IDE.
How do I do the same from the command line?
I could not find back-end commands used to collect traces in log files. XSDB and XCST do not describe trace collection options.
Ananya
sskalick
Hi Ananya,
Trace is mostly a GUI feature. There is no textual display to visualize the trace data, so the only way to capture the trace data is through the GUI.
Can you describe your requirements for not using the GUI with the trace feature?
Sam
sskalick
Hi Ananya,
Sam
ananya.muddu
Hi Sam,
Thanks for the prompt respone.
I am working on an automated workflow for profile-guided optimizations.The workflow looks like this:
Build (sdscc and tcl) -> Download (xsdb/xcst and tcl) -> Run (manually through GUI) -> Collect traces (manually through GUI) -> Analyze traces (babeltrace and python) -> Suggest optimization directions (python)
The entries in brackets are the tools used. The traces collected by SDSoC are in the CTF format. They can be viewed graphically using Trace Compass (this is what SDSoC does) or processed programmatically using the babeltrace library.
I have not found a way yet to start a trace collection run programmatically. Hence the question. Can you give me any pöointers on how I can automate trace collection runs?
- Ananya
