HughesYang
How to get run_summary file for Vitis Analyzer?
Hi, I've ZCU104 platform with Vitis 2020.1.
I used Vitis IDE to build the "vector addition example" on Hardware target successfully, and it created link_summary file as the description in Using the Vitis Analyzer document.
After that, I flashed the img into SD card, and run the example on ZCU104 by following commands:
According to the Visualizing Results and Analyzing Reports, the ".run_summary" will be generated after running application:
However, I didn't find the .run_summary file on ZCU104 anywhere...
[Q1] Did I miss any step?
[Q2] Where is the exact path in which the .run_summary file is generated?
Any help will be highly appreciated!
stephenm
Launch the Vitis Analyser, and select Open Run Summary under PROFILE
Navigate to the Run Summary:
HughesYang
Dear stephenm:
Thanks for your reply!
Sorry, maybe I don't describe clearly.
My question is where is the location for .run_summary file & why my system don't generate the .run_summary file rather than how to analyze the .run_summary file.
Thanks!
stephenm
When you run your build, this generated a run_summary file (below) that can be opened in the Vitis Analyzer
doonny
you need to add -g --profile_kernel data:all:all:all  when compiling the project
