12-19-2019 01:28 AM
Dear all,
I want to use Vitis in the same way that the SDK worked before. I create my bitstream in Vivado, export the .xsa and then start Vitis and write my C-code. I track the Vivado project and the Vitis workspace with git.
Now I want to share this project with my colleague. So he clones the git, the Vivado project works fine, but the Vitis project is practically broken. At the moment, we always recreate the entire project structure from scratch, i.e. the Platform and Application Projects.
I believe I am not using the tools not in proper way. What would be the correct way to share a Vitis project? Any help is highly appreciated.
Thank you and best regards
Eyke
12-19-2019 02:49 AM
Hi @eyke.liegmann ,
There are two methods to export the projects in Vitis tool.
1) Using the GIT HUB
1) After creating the platform project and application projects in vitis tool, Right click and select Team--> Share project.
2) Go to window --> open perspective--> select GIT perspective.
3) Select GIT staging tab
4) Now You can see the staged changes here and click on commit and push.
2) Using the Export option on Right click
1) Select the project you want to share, Go to file--> export
2) Provide the path of shared location, it will rxport to that path
3) From another machine try to import the same project using the File-->Import
12-19-2019 02:49 AM
Hi @eyke.liegmann ,
12-19-2019 02:54 AM
12-19-2019 03:12 AM
HI @eyke.liegmann ,
There is a bug in sharing the project using the explorer perspective. Hence we provided this workaround.
Please try this workaround and add you observations. we can help further if you still face the issue.
12-19-2019 05:12 AM
The export works nicely, thanks for the hint. If I understand correctly, I have to create the git repository from the eclipse gui.
What the inteded way to import the files? Do I include the git as a local repository in the new project?
Thanks and best regards
Eyke
12-19-2019 06:04 AM
Can you elaborate on option 1 using git?
This only seems to work if the folder is not already in a git directory. But what I would like to do is the folder structure to look like this:
Project_folder (this is the git header)
- vivado
- vitis
-- wrapper.xsa
-- workspace
The goal is also to be able to work on the same project from different locations and people, like a proper git repo. Is this possible in gui mode?
01-06-2020 01:04 PM
I'd like to bump this question. I'm having similar problems in trying to version control a Vitis workspace such that I can reliably clone and rebuild the software. One major problem I notice is that the platform projects have a "platform.spr" file that contains an absolute path to the hardware specification file (.xsa from Vivado hardware export). Do either of the solutions mentioned above solve this problem?
01-12-2020 11:28 PM
The "export" solution works well to share a project.
However, I do not see how to efficiently collaborate on the same project with this workflow. I could not get the git flow to work. One of the problems was always, that the platform project crashed due to the absolute file path.
