lmaxeniro
How to seamless integrate RTL project into Vitis IDE
I am able to git clone the many example projects and imported into Vitis IDE--then I can build the kernel directly in Vitis (right-click on the Hardware/Emulation-HW in the assistant window, and select build--this likely will directly call the make file)
But I can not do this to  rtl projects-- what I can do, instead, is to run "make check Target=hw/hw_emu/ PLATFORM=xxx" under command line. and this will generate the relevant HW or HW_EMU build (a folder named as "build_dir.hw.xxxxxxxxx", then I have to copy the folder into my Vitis project folder--I CAN NOT build the rtl project inside Vitis directly (by right-click on the Hardware/Emulation-HW in the assistant window, and select build)
This is not very convenient though it works OK--But I wonder is there better solution for that?
hongh
If you have created xo files with such tcl script, you can add the generated xo files into Vitis project as source files.
hongh
Please try to use RTL Wizard:
https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/devrtlkernel.html#qnk1504034323350
lmaxeniro
@honghua
Do you mean to launch a RTL wizard, then remove all rtl design and copy all customize rtl design file into it?
Also we have some tcl script as well, how to deal with that?
hongh
What's the purpose of your tcl script? To control the vivado option?
lmaxeniro
the tcl script is also from Xilinx example project, which looks likely is used for packaging to compile the xo file..
https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/rtl_kernels/rtl_vadd_hw_debug/scripts
hongh
