How to use C++ 17 standard in Vitis?
I got an error:
structured bindings only available with '-std=c++17' or '-std=gnu++17'
But I don't know where to pass this option to compiler.
For the way to add option for g++ in command line and GUI, you can refer to the snapshots. But I doubt whether C++17 std is supported in 20.1.
Thank you. When I right click project name_system and choose C/C++ build settings, there is also a "Tool settings" and I pass "-std=c++2a" in "system bulider". It amazingly works.
