lygw
How to use HBM in free-running kernel?
I want to use HBMs in free-running kernel (or other types of kernel that can always run). However, I find that in ug1393 that the free-running kernel has no memory input or output port. So is there any method to use memory like HBMs or DDRs in the kernel that can always  run? Thanks in advance!
hongh
You can try to instantiate HBM IP in RTL kernel.
hongh
lygw
Hello. Thanks for your reply. But can I just implement an ap_ctrl_none-RTL kernel with memory ports instead of instantiating HBM/DDR IP in the RTL kernel?
lygw
I also want to know what's the motivation behind the design that free-running C++ kernel can not have memory ports. Thanks in advance!
heeran
As of now, free running kernel with memory port is not supported as (my understanding) DDR memory management is still under XRT control and XRT can allocate memory and send address information  through axi lite interface to kernel. In case of free running, how XRT can send memory addresses to kernel.
If kernel is randomly read/write to any memory location, there is a chance, same memory could be allocated to some other kernel buffers and could leads to conflict.
-Heera
