aarongao
Is there available androidQ or androidR on Zynq UltraScale+ MPSoC (6cg)?
I worked on other platform with AndroidP before, and now, we move to 6cg SOC. So we try to bring up androidQ(or androidR) on 6cg,
is there any guide?
or can you give me some clue. Such as can I use "digilent" kernel as https://elinux.org/Zedboard_Android metioned.
Whether there is huge workload to finish this job?
Xilinx team has android on UltraScale+ MPSoC plan?
Look forward to your response! Thanks.
katsuki
Hi @aarongao
You may find some information by contacting our Eco Partner Mentor.
Mentor/Embedded Software/Android Services
Getting Started with Android 8 v2019.2 for Xilinx Zynq UltraScale MPSoC
Thank you.
Don't forget to Reply, Kudo, and Accept as Solution.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hi @aarongao
Thank you.
aarongao
Thanks for suggestion
