Kernel Linking Error [--sp tag applied to invalid kernel instance]
Hi, so I started with an example program (apply watermark to an image) and changed it to my encryption/decryption algorithm's logic. It works perfectly in Emulation - SW, but doesn't build in Emulation - HW. I think the problem is the build tool is trying to link the (now, non-existent) example kernel to a port instead of linking the new encryption/decryption kernels to the port. How do I specify to link the ports to the correct kernels?
BTW I changed my HW function name to "AES" and the 2 kernels within that hw function to "encrypt" and "decrypt" as you can see below in the build error message.
Creating apsys_0.xml
INFO: [CFGEN 83-0] Kernel Specs:
INFO: [CFGEN 83-0] kernel: decrypt, num: 1 {decrypt_1}
INFO: [CFGEN 83-0] kernel: encrypt, num: 1 {encrypt_1}
INFO: [CFGEN 83-0] Port Specs:
INFO: [CFGEN 83-0] kernel: apply_watermark_1, k_port: m_axi_gmem0, sptag: DDR[0]
INFO: [CFGEN 83-0] kernel: apply_watermark_1, k_port: m_axi_gmem1, sptag: DDR[1]
ERROR: [CFGEN 83-2291] --sp tag applied to invalid kernel instance: apply_watermark_1
ERROR: [CFGEN 83-2298] Exiting due to previous error
Error generating design file for apsys_0.xml
command: /tools/Xilinx/SDx/2018.3/bin/cfgen -nk decrypt:1:decrypt_1 -nk encrypt:1:encrypt_1 -sp apply_watermark_1.m_axi_gmem0:DDR\[0\] -sp apply_watermark_1.m_axi_gmem1:DDR\[1\] -r /home/kasi/workspace/study_3/Emulation-HW/AES/link/sys_link/_sds/.cdb/xd_ip_db.xml -o apsys_0.xml
Error creating intermediate design file, exiting
ERROR: [XOCC 60-398] sdx_link failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
makefile:92: recipe for target 'AES.xclbin' failed
make: *** [AES.xclbin] Error 1
thanks,
Kasi
Please refer to UG1023, pg30, XOCC Linking and Compilation Options.
As the message and you pointed out, you need to change the link option, in the makefile or other scripts you use.
brucey
Hi @kasimanikumar,
Looks like there is some problem with your link options(--sp flag) in Makefile.
Can you check the m_axi_gmem mapping in kernel and Makefile if there are properly assigned.
@kasimanikumar , if you can share the kernel and makefile code, we can debug and find the fix.
Vishnu
I'm currently using the SDaccel IDE (GUI). Whenever I modify the makefile and build it through the IDE it creates a new makefile and uses that, instead of my corrected one. How can I change this linking configuration through the IDE?
thanks,
Kasi
