OpenCL pipes equivalent for HLS kernels
I need to pass data between two C/C++ - HLS kernel. I am aware of pipes concept which can be used to to pass between two OpenCL kernels. What is the OpenCL pipes equivalent for C/C++-HLS flow.
Hi @kaliuday
you can put the 2 kernels inside the same (new) top function and have an hls::stream<> which will implement the fifo / pipe AND the top level needs to be in dataflow mode. DON'T forget to set the stream depth for the fifo which will tell the depth implemented in HW (otherwise defaults to 1).
something like this :
kernel NEWTOPKERNEL (.. args..)
#pragma HLS DATAFLOW
hls::stream<type> internalstreamimplementedasfifo;
#pragma HLS STREAM variable=internalstreamimplementedasfifo depth=42
kernelwriter(args, internalstreamimplementedasfifo);
kernelreader(internalstreamimplementedasfifo,args);
with kernelXXX(hls::stream<type> & fifo, ...args) using .read() or .write() methods for blocking reads (recommended) or read_nb/write_nb (less recommended).
i hope this helps
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Hi @kaliuday
i hope this helps
- Hervé
SIGNATURE:
hi @herver
Thanks for your response.
Currently I have two kernels (kernel1.cpp, kernel2.cpp) as 2 compute units.
I want to pipeline their executions and kernel1's output becomes input for kernel2. I dont want to use "kernel to global memory" transactions for sending input data to kernel2. Further, once the data transfer is done from kernel1 to kernel2, I want kernel1 to work on a different data set which comes from host and at the same time kernel2 works on inputs from kernel1.
hi @kaliuday
yes what you describe is what dataflow does - please read UG902 on dataflow function pipelining. any/all VHLS concept are applicable here.
the only thing to look for is the execution / wait times of the kernels and host synchronization.
cheers
- Hervé
SIGNATURE:
Hi @herver
Thanks for your answer, It worked as expected.
