RTL kernel wizard
I need assitance inthe following. When i tried to use RTL kernel wizard to generate a block design, the following error appeared.
how to get rid of this error?
[xilinx.com:ip:rtl_kernel_wizard:1.0-100] Failed to execute xsct to create and build software: "child process exited abnormally", please check /home/narasimh/Desktop/prj_folder/vitis_prj/vadd/vivado_rtl_kernel/rtl_kernel_vadd_0_ex/rtl_kernel_vadd_0_ex.sdk/xsct.log for more details.
I have attached the log file
In file included from /opt/Xilinx/Vitis/2019.2/gnu/microblaze/lin/microblaze-xilinx-elf/include/ctype.h:5, from ../../../include/xil_printf.h:8, from ../../../include/xil_io.h:59, from xbram_hw.h:57, from xbram.h:135, from xbram_sinit.c:55: /usr/include/x86_64-linux-gnu/sys/cdefs.h:23:11: fatal error: features.h: No such file or directory # include
Look like you dont have the sysroots path added. Can you add this?
