manksit
Running SW/HW emulation without physical boards
I tried to run emulation using Vitis on a development machine without any physical board attached, but I encountered the following error:
/home/workspace/Vitis_Accel_Examples/common/includes/xcl2/xcl2.cpp:31 Error calling err = cl::Platform::get(&platforms), error code is: -1001
Is it possible to emulate on a machine without hardware installed?
stephenm
You dont need to have a physical board to run the emulation. This uses QEMU and co sim (for the HW emulation)
stephenm
manksit
Thank you for your quick reply. Do you have any idea why I got this error?
bchebrol
Hi @manksit ,
You need to source Vitis and XRT before running the design. Can you try sourcing XRT, Vitis and run again.
Vishnu
