pmousoul
SDSoC 2016.4: Variable size array synthesis
Hello!
I'm trying to synthesize the following function, which it is described in my "main.hpp" as:
#pragma SDS data copy(veco[0:pM*pHout*pWout], bia[0:pM])
void hbias(float* veco, int pM, int pHout, int pWout, float* bia);
Due to the functionality of my "main.cpp" the "int pM, int pHout, int pWout" change at runtime, but are known during compile time (e.g. I add bias to the numbers of different sized arrays, which their sizes are known a priori). I would like to have one hardware function to add "bias" to the elements of each of them and not having to implement a hardware function for each different array size.
So, after selecting the "hbias" function for hardware synthesis, I get the following error:
ERROR: [SYNCHK 200-61] hbias.cpp:18: unsupported memory access on variable 'bia' which is (or contains) an array with unknown size at compile time.
Does anyone have an idea of what I'm I doing wrong?
Panos
Without proper software tools the hardware is unusable no matter how good and well designed it is.
Tags (2)
sskalick
Hi pmousoul,
The problem is given your function declaration like:
SDSoC will try and implement the arguments veco and bia as BRAMs. To implement an argument as a BRAM, SDSoC needs to know the maximum depth that argument could have. You can specify this to SDSoC by changing your pointers to arrays like:
void hbias(float veco[MAX_VECO], int pM, int pHout, int pWout, float bia[MAX_BIA]);
Then SDSoC will generate a system with argument veco implemented as a BRAM that uses enough resources to store MAX_VECO elements statically, and then only use pM*pHout*pWout elements at runtime (which must be less than or equal to MAX_VECO).
Or, if your access to veco and bia are sequential/in-order you can use the access_pattern pragma to tell SDSoC to use a FIFO for the argument like:
#pragma SDS data access_pattern(veco:SEQUENTIAL, bia:SEQUENTIAL)
In this case, the max depth (MAX_VECO) doesnt matter, since the data will stream into the accelerator.
Sam
sskalick
Hi pmousoul,
Sam
pmousoul
Sam,
thank you very much for the detailed answer!
I have one more question to make related to the third option you described:
Sam
In the above case, do I have to consume the veco[]/bia[] data in my hardware function, before I'll process it? The way you describe it, I should not consume the data in a temporary buffer in my hardware function, because this infers local memory (or should I consume it inferring a FIFO?). Could you please provide (or give a pointer in the documentation) of a complete example of a hardware function which consumes data in a streaming fashion because of the sequential nature of the processed data?
Is the following a valid streaming hardware function description taken into account the above declaration you provided (both arrays are consumed sequentially/in-order (not with the same pace, but still sequentially))?
    	for (int k=0; k<pM*pHout*pWout; k++)
                #pragma HLS PIPELINE II=1
int idx = k/(pHout*pWout); veco[k] += bia[idx]; } }
Thank you very much for your time,
Panos
sumitswaggyboy
did you get the solution ?
sumitswaggyboy
Can anyone explain or answer the last query by pmousoul in this thread ?
