leonardo_suriano
SDSoC profiling: hardware + software event tracing
Following the tutorial and the user guide UG1027 and UG1028, it is possible to create an application and profile it thanks to the "event tracing" option.
Then, the Gantt chart shows only the events related to the hardware calls, execution, control commands...of the hardware IPs on the PL. This operation is possible because of some blocks inserted in the "design block" by Vivado SDSoC, directly connected with the AXI interfaces used to exchange data with the PS.
It would be greate to have the possibility of profiling both, hw + sw, at the same time and to visualize the results on the same Gantt chart. Is there a possibility of doing that?
So far, as I said, only hw profiling was possible.
If you need more details on the project I can update the question.
Tags (2)
wsun
For SW profiling, there are a lot of choices. Please refer to SDSoC documentation for "TCF Profiling".
wsun
