Anonymous
Not applicable
SDSoC with NEON intrinsics
I am trying to compile a code with neon intrinsics. I have include arm_neon.h header and using the following compiler options:
-mcpu=cortex-a9 -mfpu=neon -mfloat-abi=softfp
However, I get a number of errors regarding types in arm_neon.h file. For instance:
/opt/applics/xilinx-sdsoc-2015.4/SDSoC/2015.4/SDK/2015.4/gnu/arm/lin/lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/include/arm_neon.h:40:9: error: unknown type name '__builtin_neon_qi'
What am I missing to use NEON in SDSoC?
bwiec
Yeah, NEON support in SDSoC is a bit messy right now because of how it's handled by the various compilers called by SDSoC.
If your hardware accelerators (or their callers) contain NEON intrinsics, protect them with __SDSCC__ and __SDSVHLS__ macros as described by UG1027.
For source files that don't contain hardware accelerators but do use NEON intrinsics, you can either compile them directly using the GNU toolchain and link the objects with sds++ or you can add the sdscc/sds++ command line options -mno-lint and -mdev-no-llvm for these source files. These commands prevent clang-based compiler from being invoked since we know they're not required (i.e. no accelerators). For the latter solution if you're using the GUI, you can apply them on a per-file bases by right-clicking the source file, select 'Properties' and go to the 'Settings' dialog under 'C/C++ Build Settings' -> 'Settings'
www.xilinx.com
bwiec
www.xilinx.com
Anonymous
Not applicable
Thanks a lot. I separated the neon functions into a separate file and in the properties of this file with neon functions I added -mno-lint and -mdev-no-llvm, as you suggested, and it worked.
Anonymous
Not applicable
Today I moved to SDSoC 2016.1.  My neon functions are in separate files and there is no neon code in the accelerator. I tried both of your suggestions (separate compilation as well as ) and they worked with SDSoC 2015.4. I was hoping it might be fixed in 2016.1, but to my surprise none of the option is working. Here are the messages when compiling externally:
/opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-g++ -Wall -O3 -I"." -c -fmessage-length=0 -MT"neon_functions.o" -Wno-unused-label -std=c++11 -mcpu=cortex-a9 -mfpu=neon -ftree-vectorize -mfloat-abi=softfp -ffast-math -MMD -MP -MF"neon_functions.d" -MT"neon_functions.d" -o "neon_functions.o" "neon_functions.cpp"
In file included from /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/features.h:402:0,
                 from /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/stdint.h:25,
                 from /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/4.9.2/include/stdint.h:9,
                 from /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/4.9.2/include/arm_neon.h:38,
                 from neon_functions.cpp:1:
/opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/gnu/stubs.h:7:29: fatal error: gnu/stubs-soft.h: No such file or directory
 # include <gnu/stubs-soft.h>
compilation terminated.
I see similar error related to stubs even with the first option.
sskalick
Im assuming that you created a new workspace, new project, and just copied your source files into this new project (in 2016.1). Is this correct?
Hopefully you didnt just open the same project/workspace that you created in 2015.4 with the new 2016.1. This will definately not work.
Sam
Anonymous
Not applicable
I think that might be the reason. I am using the same workspace but created a new project and imported files. I will try it with new workspace and creating this project in the new workspace.
Anonymous
Not applicable
Hi there,
Here are the steps I performed:
created a new workspace for 2016.1
created a new project in it
imported the source files
My neon functions are in separate files, so added the following flags (as can also be seen from the log below):
-mcpu=cortex-a9 -mfpu=neon -ftree-vectorize -mfloat-abi=softfp -ffast-math -mno-lint -mdev-no-llvm
But still no luck. Get the following error same as before.
Building file: ../src/neon_functions.cpp
Invoking: SDS++ Compiler
sds++ -Wall -O3 -I"../src" -c -fmessage-length=0 -MT"src/neon_functions.o" -Wno-unused-label -mcpu=cortex-a9 -mfpu=neon -ftree-vectorize -mfloat-abi=softfp -ffast-math -mno-lint -mdev-no-llvm -MMD -MP -MF"src/neon_functions.d" -MT"src/neon_functions.d" -o "src/neon_functions.o" "../src/neon_functions.cpp" -sds-pf zed
INFO: [SDSoC 0-0] Not running LLVM due to the -mdev-no-llvm switch
INFO: [SDSoC 0-0] Compiling /shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/src/neon_functions.cpp
                 from /shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/src/neon_functions.cpp:1:
ERROR: [SDSoC 0-0] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++ -c -I../src -Wall -O3 -fmessage-length=0 -Wno-unused-label -mcpu=cortex-a9 -mfpu=neon -ftree-vectorize -mfloat-abi=softfp -ffast-math -MMD -MP -D __SDSCC__ -MT/shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/SDRelease/src/neon_functions.o -MF/shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/SDRelease/src/neon_functions.d -MT/shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/SDRelease/src/neon_functions.d     -I /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/aarch32-linux/include  -I /opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/Vivado_HLS/2016.1/include /shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/src/neon_functions.cpp -o src/neon_functions.o'
sds++ log file saved as /shares/bulk/iashraf/zedboardWork/sdsocWorkspace2016_1/cannySW/SDRelease/_sds/reports/sds_neon_functions.log
make: *** [src/neon_functions.o] Error 1
jece
There appears to not be a soft ABI file
SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/gnu/stubs-soft.h
However there is a hard ABI file
SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/gnu/stubs-hard.h
Have you tried removing the -mfloat-abi=softfp switch from you command line?
Also, take a look at the 2016.1 release notes for SDSoC. Page 3 has some information about the ARM toolchain changes. You may need to make adjustments to other compiler switches.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug1185-sdsoc-release-notes.pdf
Anonymous
Not applicable
Hi jece,
Indeed that solves the problem.
Anonymous
Not applicable
Back again. According to the SDSoC user guide, Performance Estimation should work with any of the build configuration. But if I select this option in 2016.1, I get a lot of errors with neon, like:
INFO: [SDSoC 0-0] Starting performance estimation. This may take a few minutes
/opt/applics/xilinx-sdsoc-2016.1/SDSoC/2016.1/SDK/2016.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/4.9.2/include/arm_neon.h:40:9: error: unknown type name '__builtin_neon_qi'
typedef __builtin_neon_qi int8x8_t      __attribute__ ((__vector_size__ (8)));
The same project builds fine when I dont select performance estimation.
wsun
Can you provide your design?
Anonymous
Not applicable
Basically any project with neon code. An example attached.
sskalick
As mentioned earlier in this thread, you need to take special care of the code containing neon intrinsics. Just as you pulled the code out into a separate file so that VivadoHLS wouldnt parse the code, you need to compile that file containing neon intrinsics separately from the code you run through sdscc/++ when doing performance estimation.
Performance estimation works by instrumenting your code in various places to gather performance data. This means sdscc/++ must parse your code (in and around the hardware function) to add this instrumentation. Just like VHLS doesnt like neon intrinsics (so you moved it to another file, to avoid that problem), you need to compile the code containing neon intrinsics with the regular arm gcc/g++ compiler separately and link it in manually. This will prevent the source code from being parsed by the sdscc/++ when looking for places to instrument.
Obviously this is not an ideal solution, hopefully this will be improved in the future. But at least you can still use performance estimation now if you pre-compile it and link it in manually.
Sam
Anonymous
Not applicable
Yes, separate compilation of neon code is annoying but works.
zhangkai
I'm sorry that I could not find 'Settings' dialog under 'C/C++ Build Settings' -> 'Settings' for single source file .I want to set compile options for single file  when I use arm_neon header file under SDSoC 2019.1 GUI.
Thanks!
