Owenoool
Super Long Lines (SLLs) capacity is violated error
Hello!
I am using Vitis accel with the AWS platform (target device is xcvu9p-flgb2104-2-i if I remember correctly). I am doing sparse matrix-vector multiplication in my project. Every row in the matrix has the same number (40) of non-zero entries. In the SpMV implementation, I complete parallelized operations on these 40 non-zero entries in the vector dot product within matrix-vector multiplication.
The size of the matrix is (500x500) so the actual size is 500x40 in this case. During hardware emulation, the report shows the following resource usage:
BRAM591%
DSP2874%
FF1595436%
LUT27454923%
Then in hardware build, I encountered this error message (using all default compilation settings):
Phase 2 Global Placement
Phase 2.1 Floorplanning
ERROR: [Place 30-864] Super Long Lines (SLLs) capacity is violated between Super Logic Regions (SLR): 1 and SLR: 2 for PBlock: pblock_SH. SLLs required = 5309, SLLs available = 0.
ERROR: [Place 30-864] Super Long Lines (SLLs) capacity is violated between Super Logic Regions (SLR): 0 and SLR: 1 for PBlock: pblock_CL. SLLs required = 32436, SLLs available = 11520.
ERROR: [Place 30-864] Super Long Lines (SLLs) capacity is violated between Super Logic Regions (SLR): 1 and SLR: 2 for PBlock: pblock_CL. SLLs required = 32436, SLLs available = 11520.
Phase 2.1 Floorplanning | Checksum: b6dc6407
I understand the non-constant array access pattern built in the algorithm needs large muxes (which could be a reason), but I am wondering if there exist other possible workarounds (compilation settings/resource specifications etc.) for this issue. Please let me know if you would like me to provide more details. Thank you!!
Owenoool
hongh
It's the Vivado placer issue during the VPL. Please provide opt.dcp of the design and ask help in Implementation board.
