dat63
Unused CU
I'm trying to test the usage of multiple CUs in Vitis and a ZCU104 board. I made reference to example https://github.com/Xilinx/Vitis_Accel_Examples/blob/master/host/mult_compute_units/src/host.cpp but I rewrote it in C.
I instantiate 2 CUs with the following code:
cl_kernel krnl_vector_add[2];
for(int i=0; i<2; i++)
krnl_vector_add[i]=clCreateKernel(program, "vadd", &err);
check_cl_err(err);
When I run the application the Run Guidance in Vitis Analyzer reports:
"Compute unit vadd_1 on device zcu104_base-0 was used 2 time(s). Compute unit vadd_2 on device zcu104_base-0 was used 0 time(s). Utilize all compute units on the device"
so it seems that only 1 CU is used twice
I tried to modifiy the above code as follows:
krnl_vector_add[0]=clCreateKernel(program, "vadd_1", &err);
krnl_vector_add[1]=clCreateKernel(program, "vadd_2", &err);
but in this case I got an error during the execution saying that the system is not able to find vadd_1 and vadd_2
Any help is greatly appreciated
Daniele
