Vitis Buil sw-emulation and run correct but result different than desired one
Hi to all.
I have created host and kernel code to return the addition and the subtraction of two scalars in order to be familiar with Vitis.
Seems to compile and run correctly but the result it returns is not correct.
Host code
#include "xcl2.hpp"
#include <stdio.h>
#include <algorithm>
#include <iostream>
#include<stdlib.h>
#include <vector>
#define DATA_SIZE 2 // c[0] kai c[1]
//#define BUFFER_SIZE 1024
int main(int argc, char **argv) {
    if (argc != 2) {
        std::cout << "Usage: " << argv[0] << " <XCLBIN File>" << std::endl;
        return EXIT_FAILURE;
    std::string binaryFile = argv[1];
    size_t size_bytes = sizeof(int) * DATA_SIZE;
    cl_int err;
    cl::Context context;
    cl::Kernel krnl_add;
    cl::CommandQueue q;
     std::vector<int, aligned_allocator<int>> result(DATA_SIZE);
     for (int i = 0; i < DATA_SIZE; i++) {
       result[i] = 0;
    auto devices = xcl::get_xil_devices();
    auto fileBuf = xcl::read_binary_file(binaryFile);
    cl::Program::Binaries bins{{fileBuf.data(), fileBuf.size()}};
    int valid_device = 0;
    for (unsigned int i = 0; i < devices.size(); i++) {
        auto device = devices[i];
        // Creating Context and Command Queue for selected Device
        OCL_CHECK(err, context = cl::Context(device, NULL, NULL, NULL, &err));
        OCL_CHECK(err,
                  q = cl::CommandQueue(
                      context, device, CL_QUEUE_PROFILING_ENABLE, &err));
        std::cout << "Trying to program device[" << i
                  << "]: " << device.getInfo<CL_DEVICE_NAME>() << std::endl;
        cl::Program program(context, {device}, bins, NULL, &err);
        if (err != CL_SUCCESS) {
            std::cout << "Failed to program device[" << i
                      << "] with xclbin file!\n";
        } else {
            std::cout << "Device[" << i << "]: program successful!\n";
            OCL_CHECK(err, krnl_add = cl::Kernel(program, "vadd", &err));
            valid_device++;
            break; // we break because we found a valid device
    if (valid_device == 0) {
        std::cout << "Failed to program any device found, exit!\n";
        exit(EXIT_FAILURE);
    OCL_CHECK(err,
              cl::Buffer buffer_c(context,
            		  CL_MEM_COPY_HOST_PTR | CL_MEM_WRITE_ONLY,
                                       size_bytes,
                                       result.data(),
									   &err));
     int buffer_a = 12;
     int buffer_b = 5;
    OCL_CHECK(err, err = krnl_add.setArg(0, buffer_a));
    OCL_CHECK(err, err = krnl_add.setArg(1, buffer_b));
    OCL_CHECK(err, err = krnl_add.setArg(2, buffer_c));
    OCL_CHECK(err, err = q.enqueueTask(krnl_add));
    // Copy Result from Device Global Memory to Host Local Memory
    OCL_CHECK(err,
              err = q.enqueueMigrateMemObjects({buffer_c},
                                               CL_MIGRATE_MEM_OBJECT_HOST));
    q.finish();
    std::cout << "return value = " << result[0] <<std::endl;
    std::cout << "return value = " << result[1] <<std::endl;
    bool match = true;
    std::cout << "TEST " << (match ? "PASSED" : "FAILED") << std::endl;
    return (match ? EXIT_SUCCESS : EXIT_FAILURE);
kernel code.
#define DATA_SIZE 2
extern "C" {
void vadd(int a, int b, unsigned int *c)
#pragma HLS INTERFACE m_axi     port=c  offset=slave bundle=gmem
#pragma HLS INTERFACE s_axilite port=a               bundle=control
#pragma HLS INTERFACE s_axilite port=b               bundle=control
#pragma HLS INTERFACE s_axilite port=c               bundle=control
#pragma HLS INTERFACE s_axilite port=return            bundle=control
			c[0] = a+b;
			c[1] = a-b;
For integers 12 and 5 i declare in host code i receive the following console output.
Found Platform
Platform Name: Xilinx
INFO: Reading ../binary_container_1.xclbin
Loading: '../binary_container_1.xclbin'
Trying to program device[0]: xilinx_u200_xdma_201830_2
Device[0]: program successful!
return value = 0
return value = 0
TEST PASSED
where return value should be 17 and 7 instead of 0.
Any help guys?
Thanks in advance.
If you just change the "cl::Buffer buffer_c" definition to use "CL_MEM_USE_HOST_PTR" instead of "CL_MEM_COPY_HOST_PTR", you will get correct output.
No one to help me find the error in code?
Any help..???
If i pass in kernel
printf("Kernel result add %d\n", c[0]);
printf(" kernel result abstr %d\n", c[1]);
The results are the right ones(17 and 7) but they are not passed back to the host who still returns the value, return value=0
instead of 17 and 7.
kernel
#include <vector>
#include <stdio.h>
#include <iostream>
using namespace std;
#define DATA_SIZE 2
extern "C" {
void vadd(int a, int b,  int *c)
//#pragma HLS INTERFACE s_axilite port=size              bundle=control
//write:
      c[0] = a+b;
      c[1] = a-b;
Results
Found Platform
INFO: Reading ../vadd.xclbin
Loading: '../vadd.xclbin'
Kernel result add 17
kernel result abstr 7
return value 0
return value 0
TEST PASSED
