mostafa@sint
Vitis ignores breakpoints in kernel code
Hi All,
I am trying to debug with vitis but even when I make a new project based on the sample vadd I am not able to
stop debugger on any breakpoint. I have also checked start at the kernel start box in the debug configuration without any success.
I am working withe the sample vadd for the Alveo U250 and I try to run software emulation.
Thanks a lot for your help.
Mostafa
Tags (3)
yangc
Yes, the issue has been reported. From the internal info, it may be fixed in 2021.1.
