candycrush
Vitis run at hardware environment
I want to run at Alveo card (Environment: HW)
I built rtl kernel and host code successfully.
Also I built and run rtl kernel and host code in emulation-hw environment but when I run at hardware environment it stuck at loading xclbin file.
And when I stop running b/c it get stucked, the "terminate failed" error message occur.
Also when I try to run again, I have to reset process for board.
What is the problem for this phenomenon?
Thank u!
hongh
In HW-SW flow, if the host code has been compiled and xclbin file has been generated, you can try to execute the host's object file directly.
candycrush
I try to execute the host's object file directly, but same happening occurs.
I found that when running at Emulation-HW environment, there is no problem for reading binary file (fopen(binary_filename,"rb")).
However when running at HW environment, fopen doesn't work for long time. (I think it is not working actually.. I can't see output after fopen code)
Is it right that fopen work long time in HW environment?
Thank you!
