yan0110
What is the difference of the Application Project, Platform Project, and Library Project in SDSoC?
nutang
Hello @yan0110
Platform project is nothing but the base of your project, creating a platform project needs hardware defination as well as software. Hardware means a DSA file generated in Vivado after building your hardware system and configuring interfaces. Software components are boot files(eg. Uboot, fsbl, devicetree etc), any prebuilt libraries, emulation data files if any. Once we build software components for our target OS, we can use SDSoC platform project to add these components to the platform.
Library Project as its name suggests is useful for creating a library. Either shared library (*.so) or C-callable library (A static library of functions targeting vivado packaged IP)
Application project Creating application project based on our platform or prebuilt platform is useful for running any application on our target board. (.elf executables)
Best Regards,
Nutan
nutang
Hello @yan0110
Best Regards,
Nutan
