Why are both m_axi and s_axilite used here to declare the same port ?
It's in the page 549 of the UG1393. I don't understand why both m_axi and s_axilite are used to declare the same port like matA. Why doesn't it use just m_axi ?
Advisor
Advisor
This approach creates an AXI Master for transferring data, with the address offset of the AXI Master set via AXI Lite (Slave). It's a common design and works very well.
Advisor
Advisor
I got it ! Thank you for your reply !
