nju0441
XRT installation ERROR
Hi all,
The building env is as follows:
install package: xrt_202010.2.6.655_16.04-amd64-xrt.deb
install guidance: https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/pjr1542153622642.html
install command: sudo apt install ./xrt_202010.2.6.655_16.04-amd64-xrt.deb
Build OS: 4.15.0-112-generic #113~16.04.1-Ubuntu SMP Fri Jul 10 04:37:08 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
During the installation of XRT, some ERRORs occur:
rmmod: ERROR: Module xocl is not currently loaded
rmmod: ERROR: Module xclmgmt is not currently loaded
And some warnnigs occur:
N: Can't drop privileges for downloading as file '/home/kn/Downloads/xilinx/Vitis_Embedded_Platforms/0Xilinx Runtime - 2020.1/XRT_package/xrt_202010.2.6.655_16.04-amd64-xrt.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
Should I need to fix these? Please somebody help me.
The attachment is install log in case anyone wants a whole picture.
minx
if it is the first time to install the xrt, the following is normal.
 the second warning
it looks like a priviledge problme, please  try to install in the root, it may solve it.
nju0441
Hi minx
Thank you very much.
About “priviledge problme ”, the install command is "sudo apt install ./xrt_202010.2.6.655_16.04-amd64-xrt.deb". However, the warning is till there.....
lee_cr7
Hello
I encountered the same errors, have you solved it?
