peanut
makefile:87: recipe for target 'src/xf_corner_tracker_tb.o' failed
When I was running the example CornerTracker of Vitis-Library L3, the software simulation showed the following problem. How to solve it? thank you !!
/home/l/vitis2020.1/Vitis_Libraries-master/vision/L1/include/common/xf_structs.hpp:778:44: error: 'xf::cv::Mat<3, 1080, 1920, 1>::DATATYPE' {aka 'struct ap_uint<32>'} has no member named 'chnl'
778 | data[r * packcols + c].chnl[p][ch] = in_val;
nutang
Hi @peanut
Please mention the platform details and the link you are referring to
Best Regards,
Nutan
Hi @nutang
Im working with Vitis Vision Library on Vitis HLS , windows platform.I have got the same error .Below is the link of library i am using.
https://github.com/Xilinx/Vitis_Libraries/tree/master/vision/L1
Is there any solution ?
Thanks in advance.
Aaditya_0123
I'm facing the same error too.
Any solution to this?
scampbell
Hello all,
The code section that is triggering this error is the CopyTo function of the MAT class. Specifically, the following code section of the xf_structs.hpp as indicated in the error:
#ifdef __SDSVHLS__
data[r * packcols + c].range((p * pixdepth) + (ch + 1) * bitdepth - 1,
(p * pixdepth) + ch * bitdepth) = in_val;
#else
#endif
They key to this section of code being triggered is that the __SDSVHLS__ variable has not been set. This variable must be set when using the HLS tool compiler. To set in Vitis, use the following option:
For the L1 flow as others have mentioned, it should be part of the CFLAGS arguments for the files. Here is an example from the L1 remap example:
add_files "${XF_PROJ_ROOT}/L1/examples/remap/xf_remap_accel.cpp" -cflags "-I${XF_PROJ_ROOT}/L1/include -I ${XF_PROJ_ROOT}/L1/examples/remap/build -I ./ -D__SDSVHLS__ -std=c++0x" -csimflags "-I${XF_PROJ_ROOT}/L1/include -I ${XF_PROJ_ROOT}/L1/examples/remap/build -I ./ -D__SDSVHLS__ -std=c++0x"
These CFLAGS are set automatically by the makefile provided in the L1 directory.
OK, I hope this helps,
Scott
