opencl pipe linking stage error
Hi guys,
I am working on some OpenCL kernel which has pipe.
I have only below lines relative to the pipe implementation
1. pipe long k6_outVal __attribute__((xcl_reqd_pipe_depth(240*135)));
2. __kernel write_kernel (<has-some-inputs-outputs>)
long x1 = 0;
x1 = <do-some-operation>;
 write_pipe_block(k6_outVal, &x1);
3. __kernel read_kernel (_global long * restrict outVal, <has-some-inputs-outputs>)
int id6 = <do-some-operation>;
read_pipe_block(k6_outVal, &outVal[id6]);
compilation stage (xocc -c) is running correctly but there is error as follow in linking stage (xocc -l).
Kernel Specs:
ERROR: [CFGEN 83-1392] Illegal port name 'k6_outval_pipe' for comp 'process_data_slice6'
ERROR: [CFGEN 83-1307] getPort(k6_outval_pipe, process_data_slice6) is null
ERROR: [CFGEN 83-1316] Failed request for port named k6_outval_pipe in xd:component type process_data_slice6
/opt/Xilinx/SDx/2017.4.op/bin/cfgen: line 15:  9668 Segmentation fault      (core dumped) ${BIN_DIR}/unwrapped/lnx64.o/`basename ${LOADER}` $@
Error generating design file for apsys_0.xml
command: /opt/Xilinx/SDx/2017.4.op/bin/cfgen    -r <my_path>/work/_sds/.cdb/xd_ip_db.xml -o apsys_0.xml
Error creating intermediate design file, exiting
ERROR: [XOCC 60-398] sdx_link failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
make: *** [xclbin/kernelcode.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xclbin] Error 1
1. does anyone have familiar with above error at linking stage ?
2. Where can I find the "getPort(k6_outval_pipe, process_data_slice6)" function ?
*please note that there is no named like "k6_outval_pipe" in my openCL kernel
*my kernel name is "process_data_slice6" as mentioned in above.
Hi @brucey
I was able to find out the issue for the above error. it is due to uppercase letter in pipe variable.
I referred the UG1238, pg15
Anyway thanks your help in xcl_reqd_pipe_depth.
Thank You
Please try valid pipe depth:
Valid depth values are 16, 32, 64, 128, 256, 512, 1024,
2048, 4096, 8192, 16384, 32768.
Refer to xcl_reqd_pipe_depth command in UG1253.
brucey
Hi @brucey
Thanks for your reply,
I have changed the xcl_reqd_pipe_depth to 32768, but it gave me the same above error.
What can be the other possible reasons for above error?
Where can I find the getPort() function? (any file created in xocc -c operation, like .v, .c, .h ???)
Thank You
Hi @brucey
Thank You
