leonardo_suriano
"sds_clock_counter()" function
In the UG1027 is described how to use the function unsigned long long sds_clock_counter(void);
The question is: are the function "clock()" and "sds_cloc_counter()" different in some way? if yes in what? After, using the variable CLOCKS_PER_SEC, it seems to give me not realistic value.
code snippet:
unsigned long long start_t, end_t;
start_t = sds_clock_counter();
for(int h=0;h<100;h++)
{sobel(352/*width*/,38/*height*/,output_93632__input__0,output__input_93632__0);} // Sobel_
end_t = sds_clock_counter();
double total_t_100;
total_t_100 = (double)(end_t - start_t) / CLOCKS_PER_SEC;
printf("\tSW= %20f - %20d\n",total_t_100/100,end_t - start_t);
However, how to use it for measuring hw? Is enough something like:
#pragma SDS async(1)
#pragma SDS resource(1)
sobel_hw(output_26752__input__0,output__input_26752__0); // Sobel_2
// sobel(352/*width*/,38/*height*/,output_26752__input__0,output__input_26752__0);
sds_wait(1); // #pragma SDS wait(1)
double total_t_100;
Tags (2)
wsun
Please use the sds_clock_counter(). This is the code in SDSoC release folder (samples/mmult_optimized)
class perf_counter
public:
  uint64_t tot, cnt, calls;
  perf_counter() : tot(0), cnt(0), calls(0) {};
  inline void reset() { tot = cnt = calls = 0; }
  inline void start() { cnt = sds_clock_counter(); calls++; };
  inline void stop() { tot += (sds_clock_counter() - cnt); };
  inline uint64_t avg_cpu_cycles() { return (tot / calls); };
Please refer to the platform information for CPU frequency.
wsun
class perf_counter
public:
leonardo_suriano
That's great! I will use it. The question is: can I measure the hw function using something like:
sobel_hw(input,output);
#pragma SDS wait(1)
Will this strategy work properly (maybe up on a big number of hardware calls)?
sskalick
Hi leonardo_suriano,
What you're suggesting:
#pragma SDS wait(1)
Will work to measure the overall time to start and wait for the sobel_hw function to complete. If you want to measure the time to just start the accelerator, and separately the time you need to wait for the accelerator to finish you can do something like:
start_0 = sds_clock_counter();
end_0 = sds_clock_counter();
start_1 = sds_clock_counter();
#pragma SDS wait(1)
end_1 = sds_clock_counter();
Or you can use the tracing feature in SDSoC to automatically instrument both the software and hardware. You can turn this on in the GUI by clicking the "Enable event tracing" in the SDx Project Setting page for your project. If you're not using the GUI, you can add "-trace" to the link line when you call sds++. You can read more about SDSoC trace in UG1027 and UG1028
Sam
