reVision-Stack-on-Ultra96
I found reVision Stack on Ultra96
https://github.com/XDF2018/reVision-Stack-on-Ultra96
DPU is used in the lab
I notice DPU is  Deephi DNNDK. Does DNNDK support Ultra96?
Which version of SDSoC should I use in my pc ?
Re: reVision-Stack-on-Ultra96
Hi @hokim
Please use 2018.2 version
Best Regards,
Nutan
Hi @hokim
Best Regards,
Nutan
