sdsoc license issue
I have a nodelock license for sdsoc and I received the Xilinx.lic file. I installed my license through license manager and checked weather license has been properly configure for sdsoc. But each time I try to start sdsoc project it keep asking me for license. please have a look at the attachment.  then I copied manually to the %APPDATA%,%APPDATA%/local/xilinx,%APPDATA%/Roaming/xilinx,%APPDATA%/roaming/xilinxlicense,%APPDATA%/xilinxlicense all most everywhere I could find xilinx in appdata location but no luck.
And when I start the sdsoc project I cannot see any templates, is this related to the license? thanks
Re: sdsoc license issue
@1ymw1
The reason for license checkout failure is host ID mismatch.
The license was generated for host ID 902b347f67ff, but this host ID is not available on your machine.
You need to generate the license for one of the following Host IDs:
Network Interface Card ID : 1831bf7ee242,82c5f2667a6f,92c5f2667a6f,80c5f2667a6f,80c5f2667a6e
C: Drive Serial Number : 3c832c18
You need to rehost the SDSoC license by using steps given in this AR: https://www.xilinx.com/support/answers/36136.html
Nupur
Hi @nupurs
Kindly do the needful.
Best Regards,
Nutan
Hi @1ymw1
Please check below information.
  • Check to make sure the license file is in one of the locations where Xilinx software looks for the license. Typically, this is the ".xilinx" directory under the home drive, for example,c:\.Xilinx or ~/.Xilinx) for node-locked licenses, however, there are several possible locations where the Xilinx software might find a license. For all searched locations, go to: http://www.xilinx.com/tools/faq.htm
    and select "What are the search order and locations that Xilinx software tools (other than CORE Generator) look for a license?"
  • Make sure that the XILINXD_LICENSE_FILE is set to the expected value, if the license is not in a default location.
  • Open the license file and visually check to make sure the desired feature is found in the license file. It should follow a FEATURE or INCREMENT keyword or be a component of a package (the package name must also follow a FEATURE or INCREMENT keyword).
  • Run lmutil diagnostics on the file where the product license key is expected to be to obtain the available license keys and check-out status.
    Example: 'lmutil lmdiag -c c:\.Xilinx\xilinx.lic'
  • For LogiCORE IP license you can also run xlicmgr from the command line to see the license status.
    Example: 'xlicmgr status -c pci_express_v1 -v'
  • If you are running the software on a remote desktop, check to see that the license contains the "TS_OK" (Terminal Server OK) key. XLCM will show that the license is valid but hte software will indicate that a valid license was not found.
Best Regards,
Nutan
@1ymw1
Can you share your license file here?
Also, open Vivado tcl console and run the following command:
report_environment -file env.txt
Type "pwd" to know where the env.txt file is stored, and share the env.txt file here.
Nupur
hi @nutang
1. the license manager didnt make a .xilinx folder in the c/xilinx location or c/.xilinx so I manually made a folder and copied the license file but that also didnt work. yes I have visited that webpage already and I copied this license file everywhere as they have mentioned.
2. can you please explain me how to set the XILINXD_LICENSE_FILE value.
3. yes I did open the file using notepad++ and I have a visual confirmation of file that I have license for sdsoc until 11/2019.
4.can you explain me how to do the lmutil diagnostics?
5. I am not using LogiCORE IP license
6.I am not using remote desktop
thanks
hi @nupurs
here is the license file and env . txt
thanks
@1ymw1
Nupur
  hi @nupurs
thanks buddy, it worked. lets roll
