vitis problem
I have package a processor kernel into a vitis development. when i load a program to processor. I got this result. Some are rigtht, and others are wrong.  I want to know whether is vitis development problem or my processor have something wrong.
Is the "failed" message coming from your host/application code? I would suggest running your design via the debugger so you can step through your code and make sure that the values you are calculating are the ones you are expecting.
Please don’t forget to reply, kudo, and accept as solution!
thanks! My design has problem. I have sloved it.
