speedup
xfOpenCV Colordetect build error (reVISION)
Hello, I'm following the tutorial https://github.com/Xilinx/SDSoC-Tutorials/tree/master/opencv-to-xfopencv-migration-tutorial , and I'm now at the point where I want to build the project. When I try to do so, I get the following errors:
C:/x/zcu104-rv-ss-2018-3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include\bits/wordsize.h:32:10: error: #include nested too deeply
#include <bits/wordsize.h>
C:/x/zcu104-rv-ss-2018-3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include\bits/wordsize.h:36:2: error: "__WORDSIZE is not defined"
#error "__WORDSIZE is not defined"
C:/x/zcu104-rv-ss-2018-3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include\bits/wordsize.h:59:2: error: "Unknown __WORDSIZE detected"
#error "Unknown __WORDSIZE detected"
(They are in line 227 in attached file)
I have tried to delete everything and try over, and I have also copied the files directly from the tutorial to get them correct.
I am using a 2018.3 version of SDx and Windows 10, will also try to run it on my ZCU104 board and not ZCU102.
Thanks in advance
wenchen
Hi @speedup ,
   Refer to this post to see if there is any suggestions helpful.
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
