yasin.kagan
xfeatures2d functions wont work with gst pipeline. Erroneous pipeline: no element "sdxfilter2d"
 I'm just trying to use OpenCV library functions in reVision platform. I made a few changes on the "filter2d_cv.cpp" file of the filter2d project. These changes are:
  • comment out filter2D (iplanes[yiloc]... ); function. and related variables.
  • add cv::FAST(iplanes[yiloc],keypoints,20,false);
  • add #include <opencv2/xfeatures2d.hpp> to reaching the FAST function.
I use 2018.2 vivado SDx, and 2018.2 revision platform with usbcam and hdmi. The pipeline that I use in the terminal screen :
  gst-launch-1.0 v4l2src device=/dev/video4 ! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxfilter2d filter-preset=9 filter-mode=0 ! queue ! kmssink bus-id=b00c0000.v_mix plane-id=31 sync=false fullscreen-overlay=true
The compiler can build the project successfully, however gst pipeline gives that error:
(gst-plugin-scanner:2528): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstsdxbase.so': /usr/lib/gstreamer-1.0/libgstsdxbase.so: undefined symbol: gst_sdx_allocator_new
(gst-plugin-scanner:2528): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstsdxfilter2d.so': /usr/lib/gstreamer-1.0/libgstsdxfilter2d.so: undefined symbol: _ZN2cv4FASTERKNS_11_InputArrayERSt6vectorINS_8KeyPointESaIS4_EEib
WARNING: erroneous pipeline: no element "sdxfilter2d"
First warning seen every time. I thing the major problem is the second.
I also try different functions inside the xfeatures2d.hpp but every time element sdxfilter2d can't found (erroneous pipeline: no element "sdxfilter2d").
You can find "filter2d_cv.cpp"  file in the attachment.
Thank you in advance.
yasin.kagan
     I solve the problem by adding the library name as (opencv_XXX) into the right click on the project properties C,C++ General/Paths and Symbols/Libraries/Add... section. You can see from the SS.
     I don't know why adding library using #include on the project does not enough. Is someone knows that, an explanation will be helpful?
yasin.kagan
