Building ERROR: [VPL 17-55] 'set_property' expects at least one object.
Hi, I am trying to build the helloworld_ocl example targeting the aws vu9p-f1
$ make check TARGETS=hw DEVICES=/home/wimi/lvs/DSA_SDACCEL_AWS_VU9P/xilinx_aws-vu9p-f1_dynamic_5_0/xilinx_aws-vu9p-f1_dynamic_5_0.xpfm all
But I get the following:
===>The following messages were generated while creating FPGA bitstream. Log file:/home/wimi/lvs/ocl_xilinx/SDAccel_Examples/getting_started/host/helloworld_ocl/_xocc_link_vector_addition.hw.xilinx_aws-vu9p-f1_dynamic_5_0_vector_addition.hw.xilinx_aws-vu9p-f1_dynamic_5_0.dir/_vpl/ipi/vivado.log :
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
ERROR: [VPL 60-341] Hardware accelerator integration failed. Aborting build_system. The following log file is available for debugging '/home/wimi/lvs/ocl_xilinx/SDAccel_Examples/getting_started/host/helloworld_ocl/_xocc_link_vector_addition.hw.xilinx_aws-vu9p-f1_dynamic_5_0_vector_addition.hw.xilinx_aws-vu9p-f1_dynamic_5_0.dir/_vpl/ipi/vivado.log'. Contact your local Xilinx representative and provide the log file for further assistance.
Checking the log file:
--- DEBUG: source ./dr.bd.tcl
WARNING: [Coretcl 2-1042] No IP was identified for upgrade.
WARNING: [BD 5-230] No cells matched 'get_bd_cells /interconnect_axilite_user_slr1'
INFO: [Common 17-17] undo 'set_property'
ERROR: [Common 17-55] 'set_property' expects at least one object.
while executing
"source $dr_bd_tcl"
(procedure "ocl_util::init_ocl_project_unip" line 145)
invoked from within
"ocl_util::init_ocl_project_unip $dsa_info $config_info $clk_info $debug_profile_info"
(file "/home/wimi/lvs/ocl_xilinx/SDAccel_Examples/getting_started/host/helloworld_ocl/_xocc_link_vector_addition.hw.xilinx_aws-vu9p-f1_dynamic_5_0_vector_add..." line 180)
INFO: [Common 17-206] Exiting Vivado at Tue Sep 25 19:26:31 2018...
Not sure if the dr.bd.tcl file is using the wrong configuration:
if {[llength [get_files *.bd]] == 1} {
set diagram_handle [open_bd_design [get_files *.bd]]
} else {
set diagram_handle [open_bd_design [get_files pfm_dynamic.bd]]
upgrade_ip [get_ips]
upgrade_ip -quiet [get_bd_cells * -quiet -hierarchical -filter {VLNV =~ "xilinx.com:ip:processing_system7:*"}]
upgrade_ip -quiet [get_bd_cells * -quiet -hierarchical -filter {VLNV =~ "xilinx.com:ip:zynq_ultra_ps_e:*"}]
# Constant blocks
# Platform Parameters for xilinx_vcu1525_dynamic_5_0
set interconnect_axilite_user_slr1 [get_bd_cell /interconnect_axilite_user_slr1]
set_property -dict [ list \
CONFIG.NUM_SI 1 \
CONFIG.NUM_MI 4 \
CONFIG.M03_HAS_REGSLICE 1 \
] $interconnect_axilite_user_slr1
# Instantiating vector_add_1
set vector_add_1 [create_bd_cell -type ip -vlnv xilinx.com:hls:vector_add:1.0 vector_add_1]
# Connectivity
connect_bd_net \
[get_bd_pins /clkwiz_kernel_clk_out1] \
[get_bd_pins /interconnect_axilite_user_slr1/M03_ACLK] \
[get_bd_pins /vector_add_1/ap_clk] \
connect_bd_net \
[get_bd_pins /reset_controllers/psreset_gate_pr_kernel/interconnect_aresetn] \
[get_bd_pins /interconnect_axilite_user_slr1/M03_ARESETN] \
connect_bd_net \
[get_bd_pins /reset_controllers/psreset_gate_pr_kernel/peripheral_aresetn] \
[get_bd_pins /vector_add_1/ap_rst_n] \
connect_bd_intf_net \
[get_bd_intf_pins /interconnect_axilite_user_slr1/M03_AXI] \
[get_bd_intf_pins /vector_add_1/s_axi_control] \
sdx_memory_subsystem::map_memory_resource \
[get_bd_intf_pins /vector_add_1/m_axi_gmem] \
I built succesfully targeting the vcu1525, but always get same message when using the vu9p DSA.
Any help would be greatly appreciated!
Leo
Best,
L30nardo SV
Re: Building ERROR: [VPL 17-55] 'set_property' expects at least one object.
Though the error is reported for [2], the cause is in [1], the bd cell "/interconnect_axilite_user_slr1" is not found:
dr.bd.tcl
[1]set interconnect_axilite_user_slr1 [get_bd_cell /interconnect_axilite_user_slr1]
[2]set_property -dict [ list \
CONFIG.NUM_SI 1 \
CONFIG.NUM_MI 4 \
It seems that the platform is not correctly set.
dr.bd.tcl
CONFIG.NUM_SI 1 \
CONFIG.NUM_MI 4 \
Yes, based on example Makefiles given for AWS, the platform was not set correctly.
It seems the problem was caused by any of these xocc compiler and linker flags, respectively:
"--max_memory_ports"  and "--sp".
Thank you!
Best,
L30nardo SV
