Visitor siavashr
Direct data path from host memory to On-chip global memory
I have a question to better understanding SDAccel data flow from host to the FPGA board.
I know that as a default SDAccel passes data from the host to the Off-chip memory (board DDR).
However, I want to know that using SDAccel, is it possible to directly pass the data to the BRAMs (On-chip memories)?
I know that we can define on-chip global memories between kernels to pipeline them. But, what I'm looking for is defining on-chip global memories between the host memory (host DDR) and the FPGA without deploying off-chip DDR (on-board DDR).
Visitor siavashr
Re: Direct data path from host memory to On-chip global memory
I figured it out.
It is not possible to directly transfer data to the on-chip memory. On-chip memory is only visible by the kernels and host has no access to them.
Visitor siavashr
I figured it out.
Which version of SDAccel are you using ?
