Visitor c.timothy
HLS kernel connected through pipes with per-kernel host control
I am looking for an equivalence of the following except with HLS kernels.
https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/dataflow/dataflow_pipes_ocl/src/adder.cl
I have read the following post:
https://forums.xilinx.com/t5/SDAccel/OpenCL-pipes-equivalent-for-HLS-kernels/td-p/706580
The post proposes using a top level module with data flow, which connects each submodule together through pipes. The only problem is the I want to have better dynamic control on the host side on what is executed on each kernel. I want  that each individual kernel be able to respond to the host when it completes, and the host can send in arguments and launch each individual HLS kernels dynamically.
The example with OpenCL kernel seems to be able to achieve that, but I couldn't find an example with multiple HLS kernels connected through pipes that also allow host control to each individual kernel (without top level module).
Re: HLS kernel connected through pipes with per-kernel host control
Pipe is only supported in OpenCL and RTL kernels. It is not supported by HLS C/C++ kernels.
