How to constraint DSPs in one area in SDAccel?
    I am using VU9P as my device, and my kernel use too many DSPs(6400/6840),but it can't place in one kernel,so i am using many kernels(256DSPs one kernel) to match this issue, and i find that one SLR can't place too many kernels(just can place two kernels), i find there are too many resources not use(open project in Vivado), and my question is: how to write constraints in SDAccel to constraint one kernel in some place? thx!
Best Regards,
Stephua.
Re: How to constraint DSPs in one area in SDAccel?
Hi, @stephua ,
If you intend to appy further floorplan constraints, you can create pblock constraint by yourself in the vivado project (Save them in a tcl script) and apply them with XOCC --xp option.
Ex:
--xp "vivado_prop:run.impl_1.{STEPS.PLACE_DESIGN.ARGS.TCL.PRE}={<File
and path>}"
From 2018.3, the SDAccel linker has a new option (xocc --slr) to manually assign compute units to specific
SLRs. This feature will only work on compatible platforms.
Ex: --slr krnl_vadd_1:SLR1 --slr krnl_vadd_2:SLR1 --slr krnl_vadd_3:SLR2
Hi,hongh:
  I want to constraint area in every SLR, for example, SLR0 have 2280 DSPs, and i want to assign 6 kernels in it(one kernel use 256 DSPs),i want to constraint 6 areas to the 6 kernels.(i have tested  SLR0 can only placed two kernels(256 DSPs one kernel)routed succeed, this is why i want to constraint 6 areas),thx!
Best Regards,
Stephua.
Hi, @stephua ,
Ex:
and path>}"
